evy's avatar
evy
Wallpaper vs RV
Hi everyone,
I'm working on my very first DIY camper conversion, using a 2010 extended Ford E250.
Today I have a question regarding wallpaper, I've noticed that some RVs have them on the outside walls.
My question is, can I simply buy "standard" wallpaper with glue on the back or do I have to buy the ones you have to add glue to the back and maybe use a certain kind of glue?
After googling it I found that some were talking about factory installed heat/bonded to the plywood or commercial glue and some say residential wall paper is ok.
With the heat/cold/humidity extremes and all I just don't want to see it start peeling after a couple of months :-/
I plan on installing some on the outside walls and ceiling, but as you can see in the pictures I won't have a lot of square footage.
Thanks for any info!
  • Looks like you have got a project.. I did one many years ago I took a class A down to the frame and started all over again, took the better part of 6 months. Good luck with the re build
  • Naio -- where would you buy the wallboard with wallpaper attached that you mentioned?
    thx -- Dale
  • Naio's avatar
    Naio
    Explorer II
    You can also buy thin wallboard with wallpaper already attached, in 4x8 sheets (or metric equivalent). Fewer choices of patterns, but it might be worth checking to see if there is one you like!
    Your plan looks great :)
  • Almot's avatar
    Almot
    Explorer III
    In my trailer it is some synthetic material, probably vinyl film. Definitely not a paper. Attached to plywood panel extremely well, I suspect some thermal laminating process rather than glue.
    Not sure what you mean by "outside walls". Nobody covers exterior wall outside with wallpaper. There is normally a 1/4" interior plywood panel (covered with wallpaper), then 1.5-1.75" void filled with insulation, then exterior aluminum or fiberglass siding (or a steel sheet in motorhome).
  • jjrbus wrote:
    My 2 peso's worth. Plywood can cause some adhesion issues with various adhesives. I always coat plywood with a shellac based primer sealer before I do anything else! Zinsser Bin is a good choice. Jim
    I think I may have a gallon of this thing also:
  • westend wrote:
    If you prime the surface and then "size" it correctly, the paper should stick really well. You may want to look at wall paper that has a vinyl or other material as an outer layer as that might be more durable.
    When you say "prime the surface" you mean painting the walls/ceiling with a basic water based latex primer? before installing the wallpaper.
  • I'm envious of your project! I am redoing the inside of a 94 Toyota motorhome and know nothing about wallpaper.
    I got lucky and found a guy on the net who is a retired wallpaper hanger and RV'er. He had no issue wallpapering an RV. He suggested using Romans 935 primer, it is used to wall paper over glass and tile and other difficult surfaces. He said he would use a high clay content paste, but was up to me, i opted for pre pasted.
    In hindsight I would look for some wider wallpaper, the 21" makes too many seams.
  • If you prime the surface and then "size" it correctly, the paper should stick really well. You may want to look at wall paper that has a vinyl or other material as an outer layer as that might be more durable.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 21, 2025
