evy's avatar
evy
Wallpaper vs RV
Hi everyone,
I'm working on my very first DIY camper conversion, using a 2010 extended Ford E250.
Today I have a question regarding wallpaper, I've noticed that some RVs have them on the outside walls.
My question is, can I simply buy "standard" wallpaper with glue on the back or do I have to buy the ones you have to add glue to the back and maybe use a certain kind of glue?
After googling it I found that some were talking about factory installed heat/bonded to the plywood or commercial glue and some say residential wall paper is ok.
With the heat/cold/humidity extremes and all I just don't want to see it start peeling after a couple of months :-/
I plan on installing some on the outside walls and ceiling, but as you can see in the pictures I won't have a lot of square footage.
Thanks for any info!
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
