johnm1's avatar
johnm1
Want a "bigger" battery but where to put it?
[img] [/img]Hey all,
I have a 2015 Keystone Laredo 291TG TT and I would like to get a battery(s) that can last longer while camping without electric. I have a genny (inverter) so I can charge as needed but the Interstate HD24-DP that came with the RV just doesn't quite do it. However, I don't have much, if any more space to put a physically larger battery. If I knew how to post a pix I would. Either way, the fiberglass cap of the Rv covers the propane and the single battery box is right in front which means, if I need to get the propane bottles out (or in) I need to lift them over the top of the battery box so I can't make the box higher and since it's smuggled in the very front of the A frame, I can't really go much longer or wider either.
So ... is there a "more power" 12v battery that has the same footprint as a G24 battery?
Any other thoughts?
Thanks,
John
Edit: It helps when you read how to post a pix. Hope this image helps in understanding my fit issues.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
