MEXICOWANDERER's avatar
Mar 08, 2013
Want A Blow Up Proof Turn Signal Flasher?
Rated 25 amps maximum
  • Short circuit proof
  • Overload proof
  • High and low temperature proof
  • Reverse polarity proof
  • High and low voltage proof:Incorrect connection proof
Rated a guaranteed one million cycle life MINIMUM
Noise protection circuitry rated for emergency vehicle, ambulance
Direct short? 24 volts into a 12 volt flasher and then a direct short to ground FOR A WEEK?* Disconnect the power and the short and the flasher resumes working normally.
Have some fun and reverse the 24 volt connections and short.
This is an impressive piece of work
Blow-Up Proof Turn Signal Flasher
Having RV issues? Connect with others who have been in your shoes.24,342 PostsLatest Activity: Dec 11, 2025
