MEXICOWANDERER's avatar
Mar 08, 2013
Want A Blow Up Proof Turn Signal Flasher?
Rated 25 amps maximum
  • Short circuit proof
  • Overload proof
  • High and low temperature proof
  • Reverse polarity proof
  • High and low voltage proof:Incorrect connection proof
Rated a guaranteed one million cycle life MINIMUM
Noise protection circuitry rated for emergency vehicle, ambulance
Direct short? 24 volts into a 12 volt flasher and then a direct short to ground FOR A WEEK?* Disconnect the power and the short and the flasher resumes working normally.
Have some fun and reverse the 24 volt connections and short.
This is an impressive piece of work
Blow-Up Proof Turn Signal Flasher
  • Explosion proof? Has not been an issue recently.
    There is always hand signals :)
  • Community Alumni's avatar
    Community Alumni
    MEXICOWANDERER wrote:
    However I have read enough threads involving flashers that "inspired" me to post a link to a really good (forever) flasher. Yours may be easy to get to. Mine is, ah well, the server won't allow me to print what I think about that.
    I didn't realize that there were issues with flashers. I cannot remember the last time I had to change one, and on different brands of vehicles. But I do agree that if I had to get to one it would be an adventure even for this retired mechanic. :E
  • on my dp was installed three relays working off flasher for trailer lighting.never used them but seems like a good idea.
    I can hear them click when flashers or turn signals are on.
  • They will not fire a single lamp that has a couple of LED's but who is using that?
  • j-d's avatar
    j-d
    Explorer II
    Up to 25A so long as a minimum load requirement is satisfied. This from their webpage:
    "Contact Sure Power regarding minimum load requirements for LED compatibility."
  • I thought you were going to suggest using your arm? Though, it can be inconvient to take the screen out of the driver's window when I want to signal a turn in the MH......
    Bill
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 03, 2026
