RSD559's avatar
RSD559
Want to replace my power center
I have a small TT with a cheap power center. I want to replace it with one that meets the following criteria:
1: The fan doesn't sound like an airplane revving.
2: Doesn't blow the main fuse every time I connect the battery.
3: I can leave the trailer plugged in without boiling the battery.
4: Has a few extra 12v outputs for other projects.
No need for more than 30 amps. My old trailer had a power converter/charger that I could attach a smart module to prevent battery damage if I left it plugged in all the time. Don't want to spend a ton on this, but something better than what Keystone put in has to be out there. The box that's in there is about 6" by 10" with a pop down lid. I believe it's an EMCO 8700 series. I'll check it after work. Thanks for any input.
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 21, 2025
