calumet46's avatar
calumet46
warranty issue
I'm a brand new rv owner. We purchased a Heartland Prowler in Feb. 2017. being in the northeast our first trip was in june. During the trip we noticed that the slider was cutting the floor when it moved in and out. We brought it in for service and camper world informed us that heartland would not cover the damage. Heartland told me that because campers world had the unit for a year they should have seen the damage while showing the unit to others. I was told even though it was under warranty the damage should have been reported sooner so they were not going to cover it.
Any ideas on how to deal with this.
thanks Kevin
  • Sounds like an issue between the dealer and Heartland. Tell the dealer to fix it under warranty, it's between them and Heartland who pays, you don't care which and it's not your problem to sort that out. You're not responsible for paying for an obvious defect in material and/or workmanship.
  • dougrainer wrote:
    There HAS to be more to this story than the OP is sharing. When the OP went thru the unit when he purchased it and had his walk thru, did you not see this damage? IF there was damage, it should have been noted at that time. If you had no walk thru, THAT IS YOUR FAULT. Now, Heartland has a BAD reputation among Dealers. Numerous Dealers in our area dropped Heartland due to this type problem. Luckily, we never fell for carrying Heartland. Unless you can talk to Heartland and get them to step up, you will probably have to get a Lawyer. It may also be, (very common), that your Dealer has already been paid to fix the problem and either did not fix it or did a poor job and the problem came back. Which is why a OEM will deny warranty. I would ask Heartland direct if they have already paid for this fix on your RV. Doug
    Wow
  • Warranty starts when the first buyer takes delivery, not when it hits the dealer's lot. Something's not right with the story, but if it's true it's time to start going up the food chain.
  • The rig is still under warranty, so they should have very little wiggle room. Try your state's attorney general's office. Most have a consumer protection division.
  • In any case, true service would be for Heartland to step up and fix this
    on their dime without any finger pointing. Plain, simple, and honest.
    Brian
  • There HAS to be more to this story than the OP is sharing. When the OP went thru the unit when he purchased it and had his walk thru, did you not see this damage? IF there was damage, it should have been noted at that time. If you had no walk thru, THAT IS YOUR FAULT. Now, Heartland has a BAD reputation among Dealers. Numerous Dealers in our area dropped Heartland due to this type problem. Luckily, we never fell for carrying Heartland. Unless you can talk to Heartland and get them to step up, you will probably have to get a Lawyer. It may also be, (very common), that your Dealer has already been paid to fix the problem and either did not fix it or did a poor job and the problem came back. Which is why a OEM will deny warranty. I would ask Heartland direct if they have already paid for this fix on your RV. Doug
  • And they scream OVER REGULATION when consumer fraud is addressed by setting up arbitration or a state consumer protection agency. Brings up a point - do your homework concerning your state law. Then, no joke, contact the District Attorney relevant to that where you purchased the rig. You cannot begin to imagine the increase in interest when a D.A. telephones to get facts. It's almost humorous.
  • Dump your black tank at their service entrance when they inform you they will not honor your trailer's warranty. That'll get their attention.
    BTW...thanks for the info. I will never buy a Heartland product.
  • I'd suggest taking to someone higher up at Heartland to start. Someone is going to have to fix it.
