Scootin159's avatar
Scootin159
Water damage repair
I just bought a new (to me) toy hauler - it's a 2001 Coachmen 261TH with the Filon fiberglass sidewalls. In my pre-buy inspection I found some water damage and rot, but bought it anyways since the price was right - even if it costs me thousands to repair. Anyways, now I need to do the repair work.
First let me highlight the damage:
It's on the front left corner - and on the outside just presents itself as some cracks and bubbling in the fiberglass.
If you push on the outside wall however, you'll realize that there's no structure to it - it's likely just supported in this area by the very thin fiberglass outer skin. I'm not sure which was first - a crack in the sidewall that led to water intrusion, or water intrusion from the window just above that led to sidewall damage due to lack of structure.
On the inside you can't really see too much, since there are cabinets immediately opposite. The interior wall is completely separated (it feels much worse than it looks in the photos), with two of the drawer support brackets being attached to basically nothing.
All told the area affected is about the first 6' length of the RV, going up about 3-4' from the bottom. The front corner itself is solid, but the damage seems to really start right after the rear of the water heater door (the front most hatch in the photos).
My questions now for the community are two fold:
1) Is it safe to use the toy hauler as-is short-term? If I just cover the cracks on the outside with something to prevent further damage (eternabond, more fiberglass, etc) - do I need to worry about the trailer disintegrating driving down the road? The rest of the structure of the RV is largely sound.
2) What's the best course of action for repair? Should I cut out the skin for the damaged section, do whatever frame repair is needed, apply new skin plywood, and then re-glue the skin panel itself (doing fiberglass repair for the new seam I created when I cut off the skin)?
Moved to Tech Issues forum from DIY.
  • John Wayne wrote:
    I would think you will have to work from the inside out, and try and leave the out side skin intact.
    I too think this is the correct approach. Looking at your second picture, if you can get the cabinets, etc out of the way, I'd try to grind down and reinforce from the inside those visible cracks. They'll need a fiberglass repair on the outside also, but a couple layers of fiberglass on the inside will make that crack repair much stronger. Of course, do this before rebuilding the inside structure.
    If you can build fiberglass components for the race car, you can certainly do this repair.
    Keep us posted on the outcome as we all like to learn how.
    Fred
  • Bumpyroad wrote:
    yes
    bumpy
    What kind of roads will you use to travel. Bad roads and/or chucking could tear things up quickly.
  • TakingThe5th wrote:
    Bumpyroad wrote:
    yes
    bumpy
    Almost exclusively interstate (or various smaller highways at both ends)
  • Gjac's avatar
    Gjac
    Explorer III
    Based on the pictures and the price you paid, I would not scrap it and no it will not fall apart driving down the road. It looks to me like it was hit by something from the out side and water got in over the years and damaged the wood. If you post some pictures after you remove the cabinets of the inside and floor damage we can give you better advice. You sound like you are quite capable to make these repairs yourself and it won't cost thousands of dollars. Just keep in mind after the structure and exterior is repaired if the surface dose not look as good as you want it to you can always put a decal or false door over that area. Enjoy your MH and go camping.
  • You can use as is but you do have a project on your hands.
    I would also work from the inside out.
    Most common leaks are at roof level and then gravity takes over. You end up with a rotten roof, wall, and also floor.
  • You can do this project and still have a great RV. when you are done and you have saved thousands over a new one.
    There are posts on this forum with photos of work done like you explain.
    Take your time and enjoy the project, you may have to come up with clever solutions at times but it has and can be done.
    Good luck.
    Pogoil.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
