dcason wrote:
Doug, THERE IS NO FREEZING. I do not think i would want you trying to fix my unit.
Thanks anyway.
You want to be a jerk, then so be it. YOU DID NOT STATE IT WAS NOT FREEZING. Other posters stating they also thought it was freezing, but you did not state you were positive it was not freezing. I don't know why you would post what you said about me, when all we are trying to do is help you. Of course you do not want me to fix your unit, I would be charging you. The symptoms you have all point to incorrect install of the AC unit. If I found that to be true, you would have to pay as warranty does not cover failure to install correctly. Doug
PS, when running, the Fan keeps the water from coming back down into the RV on a faulty install. When you shut the unit down, the fan stops and the large volume of water on the Evap fins then overwhelms the evaporator drain pan.
