- ENG2242Explorer
ajriding wrote:
Electric is cheaper for those that care.
Ele is free in campgrounds if you paid already.
The gas will create more exhaust heat than the electric element. The ele element is in the water so is closer to 100% efficency where the gas loses a lot of heat to exhaust fumes. The heat in the flu or chimney could cause acceleration of rusting or degradation of material. Unlike a refrigerator, the boiler has a very short run to the outside for the gas exhaust.
With gas you are heating the outside of the container (outside of the water) and you hear creaking and cracking. You hear less cracking with the electric. So, less metal expansion is happening, less metal fatigue overall with ele since the element is in the water and nothing gets over 180 degrees in the entire ele process.
Thank you:
That is exactly the information I was looking for. I see it more and more on this forum: "misinterpret what the question is, instead of reading the black part"!!
Think about this in relative terms, not stringent scientific terms as I know people will want to argue as if this were a scientific journal... - maillemakerExplorerElectric is the way to go if you have a choice.
You don't have to get it filled up.
There is less danger of fire.
There is no danger of CO poisoning.
If electric is included in your camp site fees then it's "free". - Cummins12V98Explorer IIII run mine on electric whenever possible. Wife turns on gas on top of electric, she takes a LONG shower!
Electric/Propane water heaters are AWESOME!!! - rk911Explorer
ajriding wrote:
oldbiscuit and okhmbldr, neither of those statems makes much sense.. Can you explain?
Turn on electric once per week, run propane the rest of the time??? We will just keep on walking on that one..
6 gallon an hour recovery time? The heck does that even mean? recover time? he is heating water only.
These little 6 gallon heaters can heat water in 10-20 minutes. I dont think OP is in a race. He is just wondering which one to run. Most have suggested electric.
yup. as i wrote these days we're on electric virtually all of the time. we have thd heat assist while driving and apart from the very rare park power failure we have little need for the LP other than as a Plan B. we have a 10-gallon Atwood and can report from personal experience that there is ample hot water for another shower after ~ 15-20 minutes from the end of the previous...usually sooner in hot weather when less hot water is needed. - ajridingExplorer IIoldbiscuit and okhmbldr, neither of those statems makes much sense.. Can you explain?
These little 6 gallon heaters can heat water in 10-20 minutes. I dont think OP is in a race. He is just wondering which one to run. Most have suggested electric. - okhmbldrExplorerYears ago I had a pickup with a 100 gallon propane tank in the bed. It would run on both gas and propane. When my propane tank emptied the truck would begin to run rough, I would hit a button and it would switch to gas. I would run a full tank of gas thru the truck while I refilled the propane tank. Then I woul refill the gas tank.
Saying that; since you have a 250 gal. propane tank, why don't you just switch to electric about one day a week (or any time period that works for you) and keep everything in good working order. - wa8yxmExplorer III
2chiefsRus wrote:
I use electric when it is included in the price of the campground. I use propane when electric is not included and propane is readily available. I only turn on the water heater about 30 minutes before I plan to shower or wash clothes. Normally stays hot enough the rest of the day.
Likewise... Depends on the propane/electric price.. Some parks electricity may be cheaper but generally propane is. e - Old-BiscuitExplorer III
ENG2242 wrote:
Problematic....
Well, as I stated/implied. are there any potential mechanical issues that may develop as a result of using either/or after a prolonged period of time. This is my 10th RV, so I am familiar with them. I've just never lived in one full time. I have a 250lb propane tank, so that's not the issue. Once again, is either/or going to cause parts failure over the other after pro longed use. I'm now being redundant in an attempt to clarify a fundamental question.
Regards,
David
Only problematic when one quits working.
Then you fix it and continue using it.
Electric is slowest recovery time --- roughly 6 gal/hr from initial fill (70*F water temp)
Propane is quicker --- roughly 10 gal/hr (70*F water temp)
BOTH at same time --- 16 gal/hr
Electric vs propane
If an Atwood brand then electric element can be difficult to access. It is installed from backside of WH Tank
If Suburban brand then elctric element is easier to access as it is in outside compartment under the burner tube
Both have all propane components in outside compartment and are easy to repair
Electric element issues are usually 'operator error' ---turning it on w/o water in tank
Propane issues are usuaully due to mud dabbers or spider webs interfering with propane flow (system is only 0.4psi)
Propane spark electrode getting sooty/carboned up WILL cause ignition failures
General routine 'housekeeping' goes a long way in preventing issues. - MerrykaliaExplorer IIWe have a 250 gal tank at our S&B. We had ours filled last week, 248 gallons at $2.98 per gallon. I think electric is cheaper, but the gas is hotter and our electric water heaters were only lasting us about 3 years, just as the warranty ran out. We got a gas on-demand system, our power bill went down $50/month, but we also have the gas to pay for.
- wopachopExplorerElectric would be easier to repair. Filling up propane tanks is a pain.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
