Okie1ExplorerDec 29, 2014Water Heater - No LightI have a Suburban SW10DEL water heater and the igniter goes through its three cycles but no fire. I was wondering how you check the gas solenoid/valves. I think that one of them is bad.
jamwayExplorerDec 29, 2014Check the ground and clean it if needed. Check all the spade plugs (clips) and clean them if needed. We had about the same problem and cleaning all of that stuff fixed it. Maybe it will work for you.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 18, 2026
Related ContentAtwood water heater problemWater pump?Smelly Water HeaterWater Heater Replacement RecommendationsWhy no hot water?
