I have a Suburban SW10DEL water heater and the igniter goes through its three cycles but no fire. I was wondering how you check the gas solenoid/valves. I think that one of them is bad.
A good coil has a resistance of about 40 Ohms. There are 2 coils and both are required to work. It is a common Suburban WH failure for a coil to go open circuit.
