I have a Suburban SW10DEL water heater and the igniter goes through its three cycles but no fire. I was wondering how you check the gas solenoid/valves. I think that one of them is bad.
You can pull the 1/8 plug next to the jet and see what gas pressure you get there. My last water heater problem, everything worked right BUT a bug pooped inside my main jet. Welding torch tip cleaner was used to clean out the plugged jet. Then all worked well. Also had a jet partially plugged on my frig last year. Flame was on but not enough to cool the frig. Cleaned jet, all was ok.
