Sabluka's avatar
Sabluka
Water Heater drain plug head broke off..Remove Advice
Atwood 6-gal drain plug head broke off. Orig that came with the MW presume. 2000 yr RV.
Tryin to out how to get the threaded portion out. No water in the RV till I do.
How about putting a drill bit that is just a little larger in it, tap in a little and turn it counter clockwise.
Only other way I see is buy a large size easy-out and use that.
Any other ideas oh great sages?
rick
  • Flat head screwdriver driven in and turned with vice grip pliers
    If no center hole heat the head of screwdriver with a propane torch
  • I'm not sure if a drill bit will work since the bit has to rotate clockwise to bite into the material but the plug has to come out counter-clockwise. I used a hacksaw blade to carefully cut through it, front to back, in a couple of places then used needle nosed pliers to pull out the pieces. Another way would be to use this, which can be found at Ace, Home Depot, etc.
  • I carry a large straight-flute screw extractor, purchased at Sears. I've only used it twice, once on my rig and once to help a fellow camper.
    it worked fast and easy.
    A sprinkler nipple extractor (Lowes or Home Depot) works the same wan and just as easy. Neither damages the threads.
    Tom
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
