BFL13
May 24, 2020Explorer II
If the fault is the valve won't open, you know something is wrong and will eventually find it . In this case with it stuck open, the WH worked ok and it was some time before I noticed anything was wrong-- can be dangerous.
So I need a routine check of the WH, fridge, and furnace to catch this a lot sooner after it happens if it happens again. Sniff test at least.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
