DW says that the hot water smells. Plan is to drain it and introduce vinegar by "winterizing" but not bypassing the WH. Q. Good plan? Q. How much vinegar before filling ten gallon tank with water?...
Residential water heaters are often shipped with the temperature set to 120 degrees. It is recommended to set temperatures to 140 degrees to destroy the worst kinds of bacteria. I believe that RV water heaters are set high enough, but it would be best to check.
