WILDEBILL308
Feb 10, 2017Explorer II
There is one outher way to have the same problem. I had a drain plug leak on the hot water heater. so I closed the winter bypass valve so I could have water on in the coach while I worked on the leak. Well when I moved the valve back to the regular position the handle slipped on the valve stem and did not fully close the valve. This produced just slightly luke warm water at best.
Bill
Bill
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
