pianotuna wrote:
Does anyone know of a nylon plug that has an integrated drain valve? Thanks in advance.
:R
It isn't "rocket science", "brain surgery", require a Masters degree or even the need to stay in a "Holiday Inn" to remove and reinstall a simple little "nylon" (to keep in politically correct and not call it plastic) plug nor is it difficult to do so without causing damage or even being inconvenient..
Yes, the Attwood plug location is a bit of a pain to get to, but it CAN be done and you do not HAVE to drain it every day. ONCE A SEASON IS PLENTY or when extreme cold camping drain it before things freeze.
They DO make a special tool for removing and installing, it doesn' cost a arm or leg or you can use standard every day and easy to find socket and wrench with a short extension.
Absolutely no "need" for Anode rod, no need for drain valves or petcocks, in fact I absolutely HATED that lousy miserable brass drain petcock on the Suburban water heater my first TT had.. Blasted brass petcocks tend to get really stuck shut which requires using a pair of channel locks bending the ears and hopefully not snapping it off in the process.. And as luck had it, the Suburban petcock also was in such a place that even was a challenge to get channel locks into..
Buy the stupid NYLON PLUG and use either the special tool or a socket wrench with a short extension and move on.
The Nylon plug IS the proper tool for the job.. That is what the manufacturer designed to be used.
