msmith1199
Nov 19, 2018Explorer II
Water Heater Repair
Easy question, but a little bit of a complex explanation: My water heater shifted downward inside it's box. This caused it to tilt and cause a tear in the metal facing of the enclosure. This resulted in a piece of the exhaust deflector to drop down in front of the exhaust and block it which caused the fusible link to heat up and pop. That was how I knew something was wrong.
So the current situation is after I replaced the fusible link the water heater works fine in both electric and gas but I'm not using it with gas right now because of the tear in the metal facing. That tear would allow exhaust fumes to enter the motorhome.
I was going to just go ahead and replace the water heater, but apparently the model I have is not made anymore and the replacement is a different size which would require some modifications to make it work. So I've decided to try and just keep what I have. So I'm going to try and get in from the access in the back and move the tank up into the proper position and if I can do that I then need to repair the tear in the metal facing.
So after all that reading here is the question: Is there some type of heat proof duct type tape that I can put on the metal face? All I really need to do is seal it up so exhaust doesn't get inside the motorhome but the tear does go right up to the exhaust pipe so whatever I put on the tear has to be able to stand the heat from the exhaust. Does a tape (or something else) exist that can do this?
