Old-Biscuit
Mar 10, 2016Explorer III
rockhillmanor wrote:Casinojunkie wrote:
I have a 10 gal Atwood propane/electric hot water heater in my 5th wheel.
After about 45 min to 1 hr running time the water is so hot coming out of faucet I could scald my hands.
Is there a way to adjust the temp setting or not?
If it is scalding hot you have a problem with the thermostat!
Go outside and see how hot the side of your RV is above the hot water heater. Sounds like your tank is boiling and relief valve not working.
I had mine my thermostat go out and the hot water tank damned near burned up the entire side of the MH the tank got so hot.
Here's a news flash: the relief valves in these RV's malfunction in incidences like this 99% of the time.
I had mobile repair come out to fix mine and he said he rarely see's one of these relief valves actually work causing the near disaster that mine did when the tank overheated. And if they do work once they never work again.:(
I no longer leave the hot water heater on if I am not right there in the RV. Had that happened while I was gone, I would have sustained serious damage and/or lost my RV.
IF it is really scalding hit (hotter than the normal t-stat of 140*F) then OP has two (2) normal t-stats that have failed and two (2) ECO (HI temp) t-stats would OPEN shutting down WH.
With his system (2 separate sets of t-stats) IF the electric ECO opened he would have to manually reset it before electric would work again. If the propane ECO opened he would get a 'fault' light and would have to reset by turning Gas switch off then back on before propane would work.
Where do you get you stats on WH TPRs? Fail 99% of time and once they work that's it----------Horse pucky!
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 17, 2026
