dewey02
Mar 11, 2016Explorer II
rockhillmanor wrote:dewey02 wrote:
Wouldn't using the Water heater by-pass valve work?
Slightly open the bypass valve so that some cold water bypasses the heater and bleeds into your hot water line beyond the water heater. This will mix some cold in with the hot and bring the temp down. Keep futzing with the valve until you reach the temp that you desire.
Why wouldn't this work? And it will cost you nothing, just a bit of time.
OMG :R
Have the hot water heater checked out and get it FIXED!
Many current Fifth Wheels and travel trailers have no temperature adjustment on their hot water heater. And the non-adjustable is set at 140 degrees. Our water gets too hot to take a shower in or to wash your hands under using only the hot water. However, it doesn't get so hot that it trips the pop-off valve. This is actually NORMAL for the way most 5er and TT water heaters work. It is factory set at 140 degrees so it is NOT an error, nor is it supposed to trip the pop-off valve at that temperature. The OP said his water temp was 135 degrees, that is NOT a malfunctioning water heater.
I get that you had a bad experience, but that isn't reason for everyone to run out and have properly functioning water heaters checked, although it would probably make RV maintenance guys happy and rich.
So there is nothing to be OMG'ing about.
Yes, he can have the water heater checked out to be ultra safe, but he will spend money having it checked and probably spend even more money for whatever "fix or solution" they propose for him. You can actually purchase a replacement adjustable thermostat for the non-adjustable one that came standard on the water heater. (See the attached video which also speaks to the water at 140 degrees being too hot for most people)
Or...you can just mix in some cold water from your winter bypass valve and solve the problem yourself.
Calm down. It is all a normal situation. It is really nothing to get so excited about.
Video at this link:
https://www.youtube.com/watch?v=FuBoRRojKcA
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
