Old-Biscuit
Mar 11, 2016Explorer III
Casinojunkie wrote:dougrainer wrote:Casinojunkie wrote:
Update!!!
Did a test this morning and found water temp after heater running for 1 hour on electric was 135* using a meat thermometer. Water heater did not shut off the entire time, checking with a "Prime products A.C. Voltage tester"
Maybe my getting old is more sensitive to my skin.
Do not know what steps to take now.
Thanks for all responses.
You stated your test was on 120 electric and water heater never shut off. You used A Prime products tester. Unless you were using a AMP meter, how could you possibly know the 120 did not shut off? Where was your prime products tester connected????? 135 degrees is right where it should be. Can you please post the MODEL NUMBER of the water heater? Doug
Tester plugged into 110v close to heater, reading was 120v, Turned heater switch on and voltage dropped to 113v, shut switch off voltage bounced back to 120v. Model # CG10A-4E dated 10/26/11
Then OEM WH has been swapped out to 'newer' deign WH (4E)
That means both electric and propane use the same set of t-stats therefore you can change normal t-stat to the optional lower preset 120*F one OR the adjustable one (110*F-150*F) and have much cooler hot water output than standard (140*F)
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
