Old-Biscuit
Jul 20, 2019Explorer III
unclescratch wrote:
water heater wiring need help
I have a Suburban Model SW12DE w/both gas and electric heating. I want to move the outside (at the heater) rocker switch for the electric element to a more convenient inside switch. I have suburban's relay and the inside switch that controls both gas and electric. Question: Will the red signal light on the inside switch be used at all w/the electric heating element? I understand electric circuits pretty well, but where shall I ground the 12-volt signal wire exiting the relay? I will have to bench test the relay to determine which terminals are for 12 or 110 volts, unless someone can offer me a diagram? Thanks for whatever help you can offer ! :@
See FULL Description of 'MOD' using the DC Switches and DC Relay in your other post on that other RV Forum
Not going to repost here.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
