I have a 2014 wild wood 26 ft travel trailer and I'm trying to figure out how to adjust the hot water heater. The water is warm at the best. I checked the valves and the cold water valve is closed. Is...
I have an old attwood, I believe suburban are similar, but they come with a set temperature thermostat. Like 140 deg on mine. I did come across some literature mentioning that you can purchase one that is adjustable so you can make it hotter if you want.
Or maybe your thermostat is mis functioning. Not sure of their failure modes, but maybe its set temperature has dropped.
Get a thermometer and check water temp.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
