I have a 2014 wild wood 26 ft travel trailer and I'm trying to figure out how to adjust the hot water heater. The water is warm at the best. I checked the valves and the cold water valve is closed. Is...
There is no real adjustment for water temperature. Do you have a winterizing bypass valve? If so make sure it is closed. Make sure it is closed tight. Make sure the cold water line entering the water heater is open. What is a Pentair bypass pump? Not sure what function that would have in RV.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
