wa8yxm
Oct 12, 2017Explorer III
More symptoms please.
Suspect list
Atwood.. open the outside panel. there is a foam thing with T-Stat and ECO printed on it, there should be two RED wires hooked to the ECO, if not, re-connect.. NOTE Only selected models
Do you have 12 volt DC control voltage present at the control board?
Bad ECO, Bad T-STAT, Bad control board
NOTE IF Red wire not connected or ECO bad the FAULT indicator will come on even if you choose ELECTRIC.. Normally the FAULT indicator does not come on when on Electric.
Surburan's work differently so I can't help you with them.
Suspect list
