vampirefish's avatar
vampirefish
Water leak (again)
Hello everyone!
I thought I'd ask you experienced peeps out there about a water leak issue I'm having again. I take my 5th wheel to the same place for winter/summerizing and the first winter they bypassed the hot water heater to do so. The next year all was well... but a year after that I had a leak in a hose (crimp) that was located in the area of the new bypass. I took it in and was not charged for the "fix". Fast forward a couple years and after about the 2nd time out camping, the same issue arises. It looks under pressure (not drainage pipes). I got a call from the shop that the pipe needs to be re-crimped (duh) and that of course it will be spendy. Is there a pattern here of shoddy work or should I just always expect this type of plumbing to be sub-par? I'm guessing they just don't do very good work but don't want to make this assumption without some insight first. Thanks ahead of time!
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
