Old-Biscuit
Jan 17, 2015Explorer III
LaunchnRetrieve wrote:
Sorry, my TT is so simple that the only pair of hoses outside the trailer, one red one white, would be the water heater hoses.
I did not drain the water heater.
The only draining I did was the fresh water tank.
Surprised to see water dripping from the white hose from the water heater.
There are NO water heater hoses.
The Red pipe is low point drain for hot water lines
The White pipe is low point drains for cold water lines
Water heater is drained via drain plug in outside water heater compartment.
Sounds like cold water drain is leaking or open and draining.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
