LaunchnRetrieve
Jan 18, 2015Explorer
Old-Biscuit wrote:LaunchnRetrieve wrote:Old-Biscuit wrote:LaunchnRetrieve wrote:
Sorry, my TT is so simple that the only pair of hoses outside the trailer, one red one white, would be the water heater hoses.
I did not drain the water heater.
The only draining I did was the fresh water tank.
Surprised to see water dripping from the white hose from the water heater.
There are NO water heater hoses.
The Red pipe is low point drain for hot water lines
The White pipe is low point drains for cold water lines
Water heater is drained via drain plug in outside water heater compartment.
Sounds like cold water drain is leaking or open and draining.
OK, so there is water dripping from the low point drain line (thanks for clarification), but the plug seems tight. I'll have to figure out if the water is dripping from the plug or coming from above and dripping off the plug.
If dripping from above and down onto drain plug you need to ID where that water is coming from ASAP.
Water leaks will destroy an RV---FAST
If plug is dripping it will pour when using pump or city water connection. It needs to be fixed before next use.
Been messin' about and can't see any water signs above. Will keep looking. City water didn't increase drip.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
