StewB's avatar
StewB
Water level
How much acid should be above the plates on a lead acid battery?
Thanks for any input
Stew
  • One mechanic told me that the little ridge at the bottom of each cell-fill was the indicator as to where the fluid level was supposed to be. I've always used that as my "FULL" point.
  • The CORRECT LEVEL is that which is low enough to prevent purging at max charging and temperature. It is pre-determined by the manufacturer according to cell dimension and plate percentage fill. Start with a level 1/8" above the plates then check it again after max charge rate charging. If it did not rise a lot add a bit more water. Simple enough.
  • Really doesn't matter as long as its above. But why not play it safer,.. keep the level 1/8" below the slots at the top ? But be sure the batt is fully charged before you do that.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
