mkirsch
Sep 08, 2015Nomad II
The reason it works fine now is because the converter is no longer charging the battery. Run the battery down some and try again while the converter is in charge mode, and the problem will return.
The pump is getting dodgy. You'll have to determine for yourself if replacing the pump is worth it.
