My Sure Flow water pump runs but does not pump water. The water tank is full. ????? Any ideas as to why this might happen? Worked okay a day ago. Thanks in advance.
Air bound......open a faucet and let it run to expel trapped air
Air in leakage.....pump can't prime due to sucking air in on suction side of pump. Cracked pump casing, strainer loose/cracked, loose hose clamps. winterizing valve open
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
