hyattjlbb's avatar
hyattjlbb
Water pump airlock??
My Dad has a 2013 Coachman TT (not sure of model) and lives in SC. He was going to use it this weekend so fired up all of the systems and ran water through all of the lines. Problem he ran into was the water pump wouldn't pull water from the FW tank. Pump runs fine but all he gets is a burst of air when turning on a faucet. All water lines are working normally on city water and he did undo the bypass on the WH.
He called Camping World in Myrtle Beach where he bought it and they said it is normal when the TT sits for a while to develop an "air lock" situation. He would need to access the water pump and blow air back through using an air compressor?
Have any of you heard of this? What is the fix? I live in ND so I have never had this issue as it gets totally drained and pink stuff put in the pump. I can't help him, wondering if you guys could provide some guidance/lessons that I can pass along. Thanks!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
