i just replaced a new pump and still no water. here is a picture of the setup. I can't figure out what the clear hose and valve is for. Any help would be great. It's got to be something simple.
Double check and make sure the in-line water valve that you likely turned off when installing is turned back on. Same water valve that one turns off before they attach the hose that sucks up pink stuff for winterizing.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
