snowpekeExplorerAug 08, 2018water pump does not pumpi just replaced a new pump and still no water. here is a picture of the setup. I can't figure out what the clear hose and valve is for. Any help would be great. It's got to be something simple.
Boon_DockerExplorer IIIAug 08, 2018Here is a diagram that may help.If the clear hose with valve is the same as the diagram (antifreeze suction line) then turn off that valve and open the valve from Water Holding Tank.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpwater pumpSlow water/noisy pump
