snowpekeExplorerAug 08, 2018water pump does not pumpi just replaced a new pump and still no water. here is a picture of the setup. I can't figure out what the clear hose and valve is for. Any help would be great. It's got to be something simple.
enblethenNomadAug 08, 2018Do you have a valve to fill your fresh water tank? If so, check to make sure it is the correct position.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpwater pumpSlow water/noisy pump
