wnjj
Oct 11, 2016Explorer II
Old-Biscuit wrote:
Granted could be pump internal check valve leaking but if pump is turned on the it should cycle on/off on/off. If it doesn't then pump pressure switch is also issue.
If OP is tuning pump OFF then .....leak and that could be check valve
I rarely turn an ON-Demand pump off unless I leave.
Pump cycling with no demand alerts one to a leak.
You're right about the pressure switch. I should engage the brain before posting. If the pressure is indeed gone, the pump should want to run until it's pressurized again. If it leaks away with the faucet closed it should run again before anyone opens the faucet to find no pressure.
OP: Does the pump only run when a faucet is opened? How soon does it stop after you close it? A working system shouldn't run until you've used some water and continue running a bit after you stop.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
