RJsfishin
Oct 12, 2016Explorer
Quote:
Then turned if we turned the water off and back on there was NO water pressure what so ever No water comes out of the tap until the pump is turned on.
OP description of the problem is unclear at best.
Sounds to me if you leave the pump switch on, like you're supposed to, there would be no problem.
Leaving the pump on, if there is a leak on either side of the pump, check valve or whatever, the pump would cycle. If it does, there is a leak, probably back into the tank. If it doesn't, there is no problem.
W/o using any water, my pump does cycle now and then. Must be a check valve leaking back to the tank. It doesn't hurt anything, so I don't consider it to be a problem. If it ever starts cycling often enuff to get anoying, I will fix it.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
