Boon_Docker
Oct 12, 2016Explorer III
ggadwa wrote:
Thanks all,
No leaks were found anywhere before writing post. The pump doesn't cycle when left turned on. Wife leaves it on and I turn it off. No pressure whatsoever right after closing the sink valves if pump is off. Never used to be this way. I think I'll disassemble, clean out and reinstall. See what that does.
GARY
Check to see if you have an accumulator (very small pressure tank) inline after the pump. If there is one then that would be the reason (lost it's air pressure).
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
