SoundGuy
Oct 28, 2019Explorer
RKW wrote:
My water pump loses prime when the water tank level is showing 1/3 full.
Thoughts?
Have you considered fresh water tank sag?
Obviously if the pump's intake hose doesn't draw from the lowest part of the tank the pump it can't pump that water. I had this problem with our Freedom Express and installed braces to support the tank and ensure the bottom was flat. I also moved the draw tube which was connected to a side port on the tank to the tank drain port which was on the bottom of the tank. Solved the problem entirely. :B
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
