RKW
Oct 28, 2019Explorer II
profdant139 wrote:
RKW, what I want to know is this -- how did you get your pump to empty your tank completely so that only a little dribbled out?? Is the outflow tube mounted on the lowest point of the tank? If so, congratulations!
Ours was not, so we had it re-installed at the low point. And I put in supports, like SoundGuy did, to combat the dreaded "saggy belly" phenomenon. (Too bad it only works on RVs and not on humans.) . ;)
Well it did dribble for the best part of a half hour, so I suppose some water remained.
The only part of my tank I can see is the drain. It's enclosed and has a heater that can be turned on when needed.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
