jseyfert3
Oct 29, 2019Explorer
SoundGuy wrote:
Have you considered fresh water tank sag?
Obviously if the pump's intake hose doesn't draw from the lowest part of the tank the pump it can't pump that water. I had this problem with our Freedom Express and installed braces to support the tank and ensure the bottom was flat. I also moved the draw tube which was connected to a side port on the tank to the tank drain port which was on the bottom of the tank. Solved the problem entirely. :B
Wow, that's crazy they put that tank in there with no supports. The tank on ours is supported along both long sides with L-brackets, and has two cross bars between these side brackets to prevent sag. And the water pump draw tube was put on the bottom of the tank.
I guess we got lucky. With those two things we can drain our tank dry with the pump, provided we park the camper level.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
