Old-Biscuit wrote:
bshpilot wrote:
Old-Biscuit wrote:
You can buy a brand new Shurflo Pump #4008 (3 gpm/55 psi) for $65 LINK
I guess it depends on the pump....personally i like a little more flow than that.
Well then, how's 4 gpm/55 psi for $142 LINK
Point is you can replace a pump for a few dollars more than rebuilding them.........and you don't have to spend $200+ to do so. Just have to shop around.
or more likely (in an RV) a 5.7GPM / 65 PSI (5900 series) for $190+
the point is don't replace your (good) pump w/ a lower pressure/flow pump just to save a few bucks...especially when you can rebuild it for less.
