n7bsn's avatar
n7bsn
Water pump ponderance
Been having problems with the waterpump (Surflo series 4000?) not always shutting off.
Sometimes, when the pump brings the system up to pressure, the water pump will continue to run, either until the pump is turned off, or a faucet opened and closed.
Then, usually, it will turn off.
I've opened it up and cleaned what I could, but I'm guessing it's probably the pressure switch.
Before I go further, thoughts?
  • Thanks guy, Chris I will check both (it's good to have a real working pro on the forum)
  • I had that problem once.
    That's why I don't like the water pump to be too quiet. I want to know if it keeps running.
    Most likely the switch just needs to be adjusted. Another possibliity is if the battery is weak, it will keep pumping but not develop enough pressure to activate the switch.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
