olympicman's avatar
olympicman
Water pump switch question
I am in the process of installing the SeeLevel tank monitering system. I bought the monitor that has the water pump switch and the water heater switch.
My current system uses an Intellitec Mpx Low Side 10 amp Latching controller to make the 3 momentary switches "push on push off both same direction" work.
The SeeLevel switch is not a momentary switch it is an on off switch. Will this work with pump controller with no problems?
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 11, 2025
