pjw73nh
Jun 30, 2013Explorer
Thanks for the replies. I like the idea of re-plumbing the pump to use the drain on the bottom. It's going to take a trip or two to the RV parts store. I am fortunate to have one that lets me go into the parts bins and "put together" what I need.
I just to reiterate. I am not doubting the accuracy of the monitors. I know they are "relative indicators" at best. ***I was not out of water****. I had approximately 25% of my water left in the tank when the pump stopped. The design is ridiculous. I have had MANY RVs and this is the first one that withheld THIS much water. I can see a gallon or two....Of course you can't get ALL of it out. But TEN+ GALLONS !!!!!!! No way. Crappy design, and they should find a means of fixing it or at the very least revealing it. Not only should Keystone revise their specs to reveal a 30 gallon fresh tank, but they should also make it known that you will be carting an extra 80-90 lbs of useless cargo with you, decreasing your GCW capacity by 80 lbs.
My Sunnybrook, Lance and Colemans NEVER had this issue to this extreme.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
