astraelraen's avatar
astraelraen
Water Pump won't prime, suggestions?
We own a 2007 Nash travel trailer we purchased last year. We have never used the pump (always used campground water) Well, I was testing the pump the other day and it doesn't prime. I can't get it to prime on a tank full of water nor can I get it to prime by putting the "winterizing tube" in a bucket of water and using that as my water source.
The pump also sounds "less loud" than I am used to RV Pumps sounding. Is there any way to check the pump or should I give up and buy a new one? I'm guessing the pump is 7+ years old.
  • Chris Bryant wrote:
    A quick fix is to use a wet dry vacuum on a faucet to "pull" a prime. once primed, the pump may be fine.
    Wow Chris - I wouldn't have thought of that. Great idea!
  • A quick fix is to use a wet dry vacuum on a faucet to "pull" a prime. once primed, the pump may be fine.
  • As said earlier check to see if all of the valves are in the proper position. Since you haven't used it in years it is possible that your suction strainer is plugged and needs to be cleaned or replaced. JMO
  • This problem has been discussed previously. A few suggestions: 1. be sure all the valves are in the correct position to get water from the tank and not from the winterizing line. if there is a filter upstream be sure it is not clogged. 2. turn on the pump and open all the faucets for a couple of minutes 3. reverse the inlet valves and try to get some water into the winterizing line by holding it up vertically to put pressure on the pump inlet.
  • A new pump will solve the problem. A pump rebuild kit takes about 10 minutes to install (about the time to install the new pump) and only cost about $18.
    Try the pump kit first. IT will likely solve the problem.
    Fred.
Having RV issues? Connect with others who have been in your shoes.24,297 PostsLatest Activity: Oct 14, 2024
