perkiperki's avatar
perkiperki
Water Pump
Full water tank & no apparent water leaks. Why is pump pushing air and very little water?
  • Ok I solved it. The pump strainer input hose had a mysterious chunk of debris in it preventing sufficient water flow. Thanks for the suggestion JMO!
  • If equipped with winterizing anti-freeze valve, make sure it is closed tight.
  • Open up faucet next to water pump and let it run
    Also if you have a 'winterizing kit' on pump suction make sure it is closed and not sucking air.
    Check suction side of pump for any leaks.......cracked fittings/pump due to frozen water
  • I'll play with it some more but assume all valves correctly open. Will let you know later.
  • Are the valves all lined up correctly to the pump? Strainer plugged possibly? JMO
  • Not sure. Suspect not. It had been sputtering but now just air. Pump humms but doesn't turns off.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
