scottmartoExplorerNov 11, 2017water pumpI have a 2003 holiday rambler endeavor 40dst. Was wondering if water had to be in the system for the pump to work (fresh water tank empty). It seemed like the light came on for a second then shut off....Show More
scottmartoExplorerNov 12, 2017I guess I will check all the fuses because none of them are labeled water pump. At quick glance I did not see a in line fuse near the pump?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
Related ContentWater PumpWater Pump Failure Traveling To The EclipseWater pumpwater pumpSlow water/noisy pump
