Bomsqd's avatar
Bomsqd
Explorer III
Jun 25, 2026
Solved
Water pump?
Unsure that the water pump on my 2000 Fleetwood Bounder went out but we can’t locate the house breakers and the water pump light won’t go on when we are parked offshore can anyone help us find breakers or ultimately tell us what else we shylook at? Thanks in advance
  • Possible 26 year old pump. I’d replace as preventative maintenance.
    • Bomsqd's avatar
      Bomsqd
      Explorer III
      And that Good Sir is what we will be doing as a process of elimination but now have another major problem to contend with and will be hoping to find a decent tire dealer in the Loveland Colorado area…
  • Check to make sure both wires on the water pump are securely connected at the pump.
  • I’ve been trying to get a good driver too. Slim pickings.
  • Any of your 12 V systems working? (lights etc). Maybe you left your disconnect on? Batteries have power? Aside from that, yes, check the fuse.
    • Bomsqd's avatar
      Bomsqd
      Explorer III
      Have checked all of the above but my driver may have missed something so will forward this to him and thank you!
  • The water pump runs of the 12V DC system (battery), so it won't have a breaker in the AC panel. It will be one of the DC fuses.
    • Bomsqd's avatar
      Bomsqd
      Explorer III
      Will forward this to my driver thank you
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 02, 2026
